Hi Concept4,
You didn't include a link to a specification for your drives. I Googled and found this:
http://www.impulsecnc.nl/datasheets/leadshine/ManualM542V2.pdf
Technically they will not work with KFLOP because they specify they need 5us of Direction setup time before a Step Step pulse (see page 3). KFLOP only provides 4us. KFLOP was designed to work with high speed drives and it doesn't support this slow of a drive.
If there is not enough Direction setup time then there is a possibility of 1 uStep in the wrong direction for each reversal of motion. Eventually such an effect can result in a significant loss in position.
The only proper solution I have is to add some sort of delay circuit (ie capacitor) to give 1us of delay to the step pulses.
Here is a link to a
long cnczone Thread regarding the same or similar drives. Where it apparently works ok with only 4us of setup.
http://www.cnczone.com/forums/dynomotion_kflop_kanalog/171759-help_having_trouble_moving_my_motors-3.html
You would normally connect the Step/Dir directly to KFLOP and operate KFLOP in open collector mode where it sinks current to ground.
